using nzb name to auto rename obfuscated media files
Mierzoet
Post by Mierzoet »
Hi Alex.
Is it possible to use the name of the nzb file to auto rename obfuscated media files?
Example:
Code: Select all
Frozen.2.2019.DVDScr.XVID.AC3.HQ.Hive-CM8-Obfuscated.nzb
Comes out as:
Code: Select all
1cd2223f90263ce24a069da7cfefbcf7.avi
while UE uses 152c29cf21c049dc98fbb4c28cd6b594 as subject.
I'm not sure how UE would be able to recognize these obfuscated media files.
But not having to guess what file was downloaded would be a great feature.
grtz
WasabiNME
Re: using nzb name to auto rename obfuscated media files
Post by WasabiNME »
I believe this is already an option.
Save/Unpack tab
Unrar
Filenames: derive from NZB collection name
The unrared files will be renamed after the nzb or custom collection name only if all the
unrared files are located in the same folder and if they all have the same name (so if more
than one they all have different file extensions).
The unrared files may be located in the first level folder created by unrar without further
subfolder structure. In such a case the folder will be renamed as well.
In all other cases the unrar output will be left unchanged.
Mierzoet
Post by Mierzoet »
How could I have missed that.
Thanx a lot.
That is exactly what I was looking for.
jd
Post by jd »
Somehow this doesn't work with some new posts?
