Usenet Explorer
Forums
It is currently Thu Dec 13, 2018 2:37 am
Author Message
 Post subject: Forum names
PostPosted: Sun Jun 05, 2005 1:43 pm
Alex, any chance you could rename the forums to better reflect what's inside?
For example, I come here with this bookmark. It shows all the new posts since my last visit. Now if there are, e.g. posts in the NP forum 'Support' and one in the UE 'Support' sections, I cannot tell which they are from without a lot of navigating around as they simply say 'Support'.
I suggest naming the individual Support and Development sections with the prefix to which they are concerned. 'NP Support', 'UE Support', etc. so it will be easily visible as such with a 'New post' search.
Top
 Profile
Search for:
Jump to:
cron
