Usenet Explorer
Forums
It is currently Wed Jan 16, 2019 3:11 pm
Post new topic Reply to topic  [ 7 posts ]
Author Message
 Post subject: automatic rar/par2 decoders
PostPosted: Sat Apr 15, 2006 2:57 am
In your announcement for v1.3 you refer to automatic rar/par2 decoders. I have used one (I forget the name) with little success. Does anyone have any suggestions for ones that work well?
Steven
Top
 Profile
 Post subject:
PostPosted: Sat Apr 15, 2006 3:01 pm
been using dldone for a while
Top
 Profile
 Post subject:
PostPosted: Sat Apr 15, 2006 3:35 pm
I'm using Auto-Unpack.
Works great (and is in full development).
http://see-and-be.com/AutoUnpack/index.php
_________________
Top
 Profile
 Post subject:
PostPosted: Sat Apr 15, 2006 8:22 pm
Auto-Unpack is working great. I love it.
Top
 Profile
 Post subject:
PostPosted: Tue Apr 18, 2006 3:22 pm
I am using Grappler, can monitor different download directories.
http://home.comcast.net/~gamerscloset/
Top
 Profile
 Post subject:
PostPosted: Wed Apr 19, 2006 6:51 pm
I'm newly converted. Been using Auto unpack instead of DLDone. Thanks for bringing this up!
Top
 Profile
 Post subject:
PostPosted: Sun Apr 30, 2006 9:06 am
I am not impressed by "Auto Unpack", it does not handle the unpacking correctly for some files. In fact, "Auto Unpack" shows error messages while other programs can handle the same files. There is another automatic unpacking, which may not be much better than "Auto Unpack". If you want to give it a try, look for Par-N-Rar at http://www.milow.net/site/projects/parnrar.html
While I have not seen a good program for automatic postprocessing, the manual postprocessing with QuickPar http://www.quickpar.org.uk/ seems to be quite good. Manual postprocessing means that one has to load a par file, the rest can be done automatically as well.
Top
 Profile
Search for:
Jump to:
cron
