splitting/manual joining attachments/posts?
dengle
Post by dengle »
Is there a way to split and manually rejoin an autojoined file? for instance, a 30 part attachment is missing part 20. Due to the missing part, it's listed as an incomplete download.
The poster reposts part 20 separately. I need to be able to join the two.
you need to select all parts and then to invoke from the context menu more->manual reassembly, then newpsro will create a single header with the body of the combined partial.
dengle
Post by dengle »
wow, i must be blind. didn't even see the "more" menu option!
