[REQ] Sorting rules in the filter editor
Gul
Post by Gul »
By drag & drop and / or keyboard.
Another thing is the inability of applying more than one setting to a multiline selection. Select more than one rule (line) in the filtereditor and click Select / Extract / Ban. Only the last one rule is changed.
Thx Gul
You can use copy/paste buttons, it is not like the post dialog where the order is more significant, just it is a less (if at all) used function so it is less elaborated.
Selecting more than line line is for deleting, suppose, if you change 'subject' contains to 'author' 'contains' while all conditions are selected and it would change everything ('lines', 'dates', 'messages are') to 'author' 'contains' it just won't make sense.
