25 Apr 25: The search service monitor sound alarm was not always activated to alert me in the case of an unplanned server restart (e.g. tripped breaker) like it happened today. This is now fixed and thus the search service downtime of this nature is less likely.
Most of the time, and unfortunately when I need it the most, the search engine is inaccessible for me.
Now, I know that sometimes the search engine is truly down but I suspect that I too have a problem on my end.
For exemple, sometimes my friend can access it while I cannot (he is using another ISP, another machine, another whatever...)
I would like to know if there are some tests that I can perform whenever it is not working so I can debug the problem and maybe work on it with my ISP or on my machine or whatever...
