Connection refused (10061)
Marten Fokkens
Post by Marten Fokkens »
I have many errors when I try to connect the search server.
I think it is already 2 or 3 weeks now.
Search failed(5)
One time it works , the other time not.
Maybe a capacity problem?
Just one time Search failed (1) - system 10061
Several time : Search failed (9) - system 10061
Re: Connection refused (10061)
10061 is connection refused. Most likely the problem is with your computer, maybe router or firewall. With those errors above I can tell the errors are random and don't depend on the destination IP address (those errors belong to different locations).
The "Connection attempt failed because..." message code is 10060, one would get it if there is a routing problem or if the search service connectivity is down. Sometimes I had here periods of bad connection quality, then also in browser I randomly got an error page, in UE the search error was 10060, not connection refused.
Marten Fokkens
Re: Connection refused 10061
If I translate it in English:
The connection is active refused by the target computer......
Is that your computer or mine? I don't know.
It is not search service computers, since there are two physical locations with completely different connection setup and you get random errors from both locations, but it may well be your firewall or router, they usually return this error. Try to disable firewall / connect directly without or reset router to see if it is the case.
Also maybe you remember something changed around the time when the problem started, e.g. you installed firewall update or replaced router.
Marten Fokkens
I changed nothing and I just did 20 searches and there was not any fault.
Strange.
Most likely the problem is still there, it may depend on other things, e.g. it may happen when you load the connection and in the same time you make a search, the bug is triggered, some kind of sync issue maybe.
Marten Fokkens
We will see. If I need your help I will tell you.
For now thank you for your assistance and I wish you a nice weekend.
