Download limit suspend server time
plasmannc
Post by plasmannc »
Alex,
One of the options on the general tab is to suspend the server for an amount of time if that servers download limit has been exceeded. The amount of time to suspend is given in minutes.
Is it possible to enter a specific time such as 3 AM rather than minutes? If not is it possible to add such a feature to Newspro? My reason for asking is that my servers reset at 2AM. At present I have to calculate the minutes from reaching the limit till 2 AM each time (no big deal) and enter that number. Would be nice if I could just enter 2 AM and forget it
Thanks for a great program :D :D
in the workspace in the server context menu (the second pane) there is an option to reset download limit&bandwidth counters at certain time. you can select several servers at once.
plasmannc
Post by plasmannc »
Alex,
Thanks for the response. I am not sure if I have this correct so please bear with me.
I assume you are refering to the "autoreset" function on the server pane. First should I set the value for "server suspend" on the general tab to "0" minutes?
If I then use autoreset and set it for 2 AM or 02:00 hours when a server reaches its dl limit will it then suspend until 2 AM when the sever resets?
Thanks as usual
