Suggestion: "Export Headers to nzb" filename chang
stevelon
Post by stevelon »
I like the export headers option and I use it all the time. I also like the fact that I don't have to come up with a filename because UE handles that for me from the header information.
I tend to keep the nzb files as a record of stuff I've downloaded, and to be able to re-download stuff easily, so it's a good feature all around.
However, the filename is always stored as [dd-mon-yy] <headerline>.nzb. This naming convention makes it harder to sort the filename properly, since 03-Nov-05 files will be right next to 03-Dec-05 files instead of next to 04-Nov files etc
Please consider a small change to save the name beginning with [yy-mm-dd] to enable sorting on date?
Thanks.
