UE Download folder deleted on UE activation
stevelon
Post by stevelon »
Hi Alex.
My download folder for UE happens to be on a disk that is mounted to another drive.
The configured UE download folder is, say, g:\DL\UE, where g:\DL\UE itself was an empty folder upon which another disk was mounted, and it is here that downloads are meant to go.
Most of the time (but not always) activation of UE.exe causes the unmounting of the mounted disk and deletion of the "UE" empty mount point folder.
I've been getting around this by starting UE, recreating the UE folder under g:\DL if it has disappeared again and remounting with diskmgmt.msc
It's been an issue with many new releases of UE so I'm guessing nobody else has ever raised this, but if you can fix this that would be great.
Thanks for looking at this.
Re: UE Download folder deleted on UE activation
Hi Steve,
Is it something related to Edit menu->Properties->Unpack "Delete empty save folders" or it is something else?
I see it is checked by default.
stevelon
Post by stevelon »
Hi Alex,
I've cleared that setting and the problem hasn't happened since (although it was always hit and miss)
I wonder if whatever system call(s) you use to check for empty folders don't always check if the folder is currently in use as a mount point...
Anyway. It seems to be OK now. Thanks for the quick response.
The program only calls ::RemoveDirectory, it doesn't know anything about mounted folders, the rest is how the system handles that
https://learn.microsoft.com/en-us/windo ... directorya
The description mentions something about links.
What can be done when the option is checked but the save path starts with \\ such empty save folders won't be deleted.
When you saved to that folder previously and the files are still listed in the unpack pane and the files are not in that folder any more on program restart only then it will call RemoveDirectory on that folder which will fail if it is not empty (but apparently the call will unlink it even if it is not empty).
In the next release it won't touch paths starting with \\ so it will be the way to go if you would prefer the option checked.
stevelon
Post by stevelon »
Hi Alex. Unticking the option is fine for me. Problem solved :-)
If you are talking about paths starting with \\ and you want to try it with the checkbox checked I can compile a version and send you a link.
I just added
&&strncmp(*folder,"\\\\",2) before &&::RemoveDirectory(*folder) so it won't proceed there
But if it is a different method of mounting better just keep that checkbox unchecked.
