[req] Download packages
andreasfc
Post by andreasfc »
This really rocks for the best newsreader program.
Thanx for implementing this feature Alex, it is a pitty though that you need to pay for newzbin.
Maybe there will be a special group for this kind of stuff (it is just an option).
jaapf
Post by jaapf »
For now, it is still possible voor free-users to download ID-packages at NewzBin.com. Don't no whether it will be in the future.
Only drawback vor NewzBin.com is that the post isn't available until the last part has been posted. So you will need a good retention on you newsserver for the larger postings, and posters with a slow upload.
Erik
Post by Erik »
I tried it also with NP3714 and NP3715, the clipboard copy worked.
Then I tried it with a few nzb files, only one file worked for 1 time. The other 25 times not (even the that worked first).
I import the the file 10 times, but the #~import group stays empy
Any ideas what i can do to solve it?
ps the file are good because someone else tried a nzb file from me on his version of NP and it worked.
I use 7 xpat groups, 15 normal groups (but most are empty) and 8 servers
The nzb files are only 4kb to 150kb
probably you saved attachments and deleted the headers, so you can see the headers in edit menu->show deleted headers;
you reminded me, i thought maybe to treat the group in such a way that its deleted headers won't be remembered.
rtwo
Post by rtwo »
I have two databases, I start the first one just using "Newspro.exe" this loads the default database, and the second one using "newspro.exe data2" loading the second database. I made two shortcuts.
When I associate NZB to Newspro and doubleclick on a .NZB file the first one always opens, but instead of that I want to start Newspro, opening the second database, is there a way to do that??
btw, thanx for this new feature :wink:
you can rename the profile to 'import' but how it stands now (3715) - it should be running, first it looks among running instances for the import profile, then for the default profile; if nothing has been found it will launch the first running profile found.
maybe something better is possible, e.g. it will launch the import profile anyway if it exists in registry, the only problem then if you stop using the profile one would need to manually delete it from the registry, maybe to make it an option.
Erik
Post by Erik »
alex wrote:probably you saved attachments and deleted the headers, so you can see the headers in edit menu->show deleted headers;
Alex: That did the trick :D
When testing newzbin. I used something i remembered from dloading the day before.
When i used show deleted headeres everything was there :oops:
jaapf
Post by jaapf »
NPro run's now like it never ran before, exploring new territory's on usenet.... (sorry, just watched a episode of Star Trek......)
Looks like you're close to a new versionrelease.
Still, the problems with the timecounter and progressionbar's haven't changed.
Some xtra info: The bar's and time are working fine when downloading with headers acquired from a Header-download or Xpat. Only when downloading from imported Headers the problem occurs. Hence my idea it has something to do with way you make the headers flow form the #-import group to the download part of the program.....
do you refer to binnews, newzbin or www.binaries.nl?
can you email me the .zml/.nzb file itself or paste binaries.nl page here as text?
it must be an error in the index file data, the arithmetics is straightforward, i've just rechecked it while writing this reply.
probably you see wrong size in the .nzb file (you cannot check .zml directly but i could check it here). for binaries.nl there is total number of lines, i just divide it by the number of parts.
jaapf
Post by jaapf »
Indeed the problem only seems to occur with Binaries.nl......
With a NewzBin-file everything works fine.
I notice that they show at Total number of lines......
Could it be you use the total number of lines for each segment?
(which at least would explain the time error, and give a incorrect scale for the progress-bar)
If that's the case, I don't think the problem can be solved (at least not completely) cause there might be a bigger problem if the number of lines is to small (ie 51319561 divided by 131 probably won't be correct too if the poster didn't adjust the size of his attachement to fit in a multiple of the number of Yenc-lines he uses to post) ommitting the last line(s) from each segment, if the last segment is smaller then the rest.
I used the folowing clipboard to test:
Home Topics Diverse - Games - Movies - MP3 - Software Search Advanced - Req. Group
Filename: Gallische_vecht_ster_DVD3.part010.rar
Description: (Eucalypt repost) [10/10]
Poster: Eucalypt
Newsgroup: alt.binaries.x
Receive Date: 06 Jan 05:04
Total Lines: 51319561
Parts: 131
Message-ID's Part 1/131 <XGpKb.22857$4N2.20456@fe08.usenetserver.com>
Part 2/131 <aHpKb.22863$4N2.3315@fe08.usenetserver.com>
Part 3/131 <oHpKb.22868$4N2.12687@fe08.usenetserver.com>
Part 4/131 <BHpKb.22875$4N2.18550@fe08.usenetserver.com>
Part 5/131 <JHpKb.22877$4N2.1171@fe08.usenetserver.com>
Part 6/131 <RHpKb.22879$4N2.11010@fe08.usenetserver.com>
Part 7/131 <YHpKb.22884$4N2.8429@fe08.usenetserver.com>
Part 8/131 <4IpKb.22886$4N2.17476@fe08.usenetserver.com>
Part 9/131 <cIpKb.22889$4N2.8089@fe08.usenetserver.com>
Part 10/131 <jIpKb.22892$4N2.17444@fe08.usenetserver.com>
Part 11/131 <rIpKb.22895$4N2.1681@fe08.usenetserver.com>
Part 12/131 <zIpKb.22899$4N2.7837@fe08.usenetserver.com>
Part 13/131 <HIpKb.22902$4N2.5081@fe08.usenetserver.com>
Part 14/131 <OIpKb.22904$4N2.2784@fe08.usenetserver.com>
Part 15/131 <WIpKb.22908$4N2.10001@fe08.usenetserver.com>
Part 16/131 <1JpKb.22911$4N2.19725@fe08.usenetserver.com>
Part 17/131 <9JpKb.22913$4N2.12278@fe08.usenetserver.com>
Part 18/131 <hJpKb.22916$4N2.18259@fe08.usenetserver.com>
Part 19/131 <oJpKb.22919$4N2.17812@fe08.usenetserver.com>
Part 20/131 <wJpKb.22922$4N2.9887@fe08.usenetserver.com>
Part 21/131 <EJpKb.22925$4N2.19901@fe08.usenetserver.com>
Part 22/131 <LJpKb.22928$4N2.484@fe08.usenetserver.com>
Part 23/131 <TJpKb.22932$4N2.12307@fe08.usenetserver.com>
Part 24/131 <%JpKb.22935$4N2.12263@fe08.usenetserver.com>
Part 25/131 <6KpKb.22937$4N2.21342@fe08.usenetserver.com>
Part 26/131 <eKpKb.22940$4N2.7314@fe08.usenetserver.com>
Part 27/131 <mKpKb.22944$4N2.8308@fe08.usenetserver.com>
Part 28/131 <tKpKb.22946$4N2.13681@fe08.usenetserver.com>
Part 29/131 <BKpKb.22948$4N2.18081@fe08.usenetserver.com>
Part 30/131 <JKpKb.22952$4N2.2452@fe08.usenetserver.com>
Part 31/131 <QKpKb.22955$4N2.11782@fe08.usenetserver.com>
Part 32/131 <YKpKb.22957$4N2.21671@fe08.usenetserver.com>
Part 33/131 <4LpKb.22960$4N2.13517@fe08.usenetserver.com>
Part 34/131 <bLpKb.22965$4N2.10157@fe08.usenetserver.com>
Part 35/131 <jLpKb.22967$4N2.12939@fe08.usenetserver.com>
Part 36/131 <qLpKb.22970$4N2.13657@fe08.usenetserver.com>
Part 37/131 <yLpKb.22972$4N2.5243@fe08.usenetserver.com>
Part 38/131 <GLpKb.22976$4N2.19296@fe08.usenetserver.com>
Part 39/131 <NLpKb.22979$4N2.11936@fe08.usenetserver.com>
Part 40/131 <VLpKb.22981$4N2.20799@fe08.usenetserver.com>
Part 41/131 <1MpKb.22985$4N2.15291@fe08.usenetserver.com>
Part 42/131 <8MpKb.22988$4N2.10696@fe08.usenetserver.com>
Part 43/131 <gMpKb.22990$4N2.5845@fe08.usenetserver.com>
Part 44/131 <oMpKb.22993$4N2.15385@fe08.usenetserver.com>
Part 45/131 <vMpKb.22997$4N2.9741@fe08.usenetserver.com>
Part 46/131 <DMpKb.23000$4N2.6974@fe08.usenetserver.com>
Part 47/131 <LMpKb.23003$4N2.22636@fe08.usenetserver.com>
Part 48/131 <SMpKb.23005$4N2.8162@fe08.usenetserver.com>
Part 49/131 <_MpKb.23009$4N2.14944@fe08.usenetserver.com>
Part 50/131 <6NpKb.23012$4N2.5295@fe08.usenetserver.com>
Part 51/131 <eNpKb.23014$4N2.20675@fe08.usenetserver.com>
Part 52/131 <lNpKb.23017$4N2.21553@fe08.usenetserver.com>
Part 53/131 <tNpKb.23021$4N2.3769@fe08.usenetserver.com>
Part 54/131 <BNpKb.23023$4N2.7862@fe08.usenetserver.com>
Part 55/131 <INpKb.23026$4N2.15220@fe08.usenetserver.com>
Part 56/131 <QNpKb.23030$4N2.2428@fe08.usenetserver.com>
Part 57/131 <YNpKb.23033$4N2.15114@fe08.usenetserver.com>
Part 58/131 <3OpKb.23035$4N2.13995@fe08.usenetserver.com>
Part 59/131 <bOpKb.23039$4N2.8683@fe08.usenetserver.com>
Part 60/131 <jOpKb.23042$4N2.1935@fe08.usenetserver.com>
Part 61/131 <qOpKb.23044$4N2.719@fe08.usenetserver.com>
Part 62/131 <yOpKb.23048$4N2.8727@fe08.usenetserver.com>
Part 63/131 <GOpKb.23050$4N2.935@fe08.usenetserver.com>
Part 64/131 <NOpKb.23054$4N2.19772@fe08.usenetserver.com>
Part 65/131 <VOpKb.23057$4N2.7872@fe08.usenetserver.com>
Part 66/131 <0PpKb.23060$4N2.21200@fe08.usenetserver.com>
Part 67/131 <9PpKb.23062$4N2.4645@fe08.usenetserver.com>
Part 68/131 <hPpKb.23066$4N2.9404@fe08.usenetserver.com>
Part 69/131 <oPpKb.23069$4N2.13501@fe08.usenetserver.com>
Part 70/131 <wPpKb.23071$4N2.7521@fe08.usenetserver.com>
Part 71/131 <DPpKb.23074$4N2.8055@fe08.usenetserver.com>
Part 72/131 <LPpKb.23078$4N2.5855@fe08.usenetserver.com>
Part 73/131 <TPpKb.23080$4N2.10951@fe08.usenetserver.com>
Part 74/131 <_PpKb.23084$4N2.15670@fe08.usenetserver.com>
Part 75/131 <6QpKb.23086$4N2.21095@fe08.usenetserver.com>
Part 76/131 <eQpKb.23090$4N2.22954@fe08.usenetserver.com>
Part 77/131 <lQpKb.23093$4N2.5820@fe08.usenetserver.com>
Part 78/131 <tQpKb.23095$4N2.2158@fe08.usenetserver.com>
Part 79/131 <BQpKb.23099$4N2.1883@fe08.usenetserver.com>
Part 80/131 <IQpKb.23102$4N2.8258@fe08.usenetserver.com>
Part 81/131 <QQpKb.23104$4N2.12755@fe08.usenetserver.com>
Part 82/131 <YQpKb.23106$4N2.6469@fe08.usenetserver.com>
Part 83/131 <4RpKb.23111$4N2.2576@fe08.usenetserver.com>
Part 84/131 <bRpKb.23113$4N2.15032@fe08.usenetserver.com>
Part 85/131 <jRpKb.23115$4N2.16942@fe08.usenetserver.com>
Part 86/131 <rRpKb.23118$4N2.6874@fe08.usenetserver.com>
Part 87/131 <yRpKb.23122$4N2.17098@fe08.usenetserver.com>
Part 88/131 <GRpKb.23124$4N2.16613@fe08.usenetserver.com>
Part 89/131 <ORpKb.23127$4N2.6692@fe08.usenetserver.com>
Part 90/131 <VRpKb.23131$4N2.22905@fe08.usenetserver.com>
Part 91/131 <1SpKb.23134$4N2.9728@fe08.usenetserver.com>
Part 92/131 <8SpKb.23137$4N2.17354@fe08.usenetserver.com>
Part 93/131 <hSpKb.23140$4N2.225@fe08.usenetserver.com>
Part 94/131 <oSpKb.23142$4N2.7458@fe08.usenetserver.com>
Part 95/131 <wSpKb.23146$4N2.15486@fe08.usenetserver.com>
Part 96/131 <ESpKb.23148$4N2.19734@fe08.usenetserver.com>
Part 97/131 <LSpKb.23152$4N2.17802@fe08.usenetserver.com>
Part 98/131 <TSpKb.23155$4N2.15464@fe08.usenetserver.com>
Part 99/131 <_SpKb.23158$4N2.13380@fe08.usenetserver.com>
Part 100/131 <6TpKb.23161$4N2.10316@fe08.usenetserver.com>
Part 101/131 <eTpKb.23163$4N2.8403@fe08.usenetserver.com>
Part 102/131 <lTpKb.23166$4N2.8086@fe08.usenetserver.com>
Part 103/131 <tTpKb.23168$4N2.3934@fe08.usenetserver.com>
Part 104/131 <BTpKb.23170$4N2.10485@fe08.usenetserver.com>
Part 105/131 <ITpKb.23173$4N2.6499@fe08.usenetserver.com>
Part 106/131 <QTpKb.23176$4N2.21339@fe08.usenetserver.com>
Part 107/131 <YTpKb.23178$4N2.1059@fe08.usenetserver.com>
Part 108/131 <3UpKb.23180$4N2.16560@fe08.usenetserver.com>
Part 109/131 <bUpKb.23183$4N2.5489@fe08.usenetserver.com>
Part 110/131 <iUpKb.23186$4N2.9807@fe08.usenetserver.com>
Part 111/131 <qUpKb.23189$4N2.9088@fe08.usenetserver.com>
Part 112/131 <yUpKb.23191$4N2.9677@fe08.usenetserver.com>
Part 113/131 <FUpKb.23194$4N2.18629@fe08.usenetserver.com>
Part 114/131 <NUpKb.23197$4N2.11363@fe08.usenetserver.com>
Part 115/131 <VUpKb.23199$4N2.11670@fe08.usenetserver.com>
Part 116/131 <0VpKb.23202$4N2.1575@fe08.usenetserver.com>
Part 117/131 <8VpKb.23204$4N2.19798@fe08.usenetserver.com>
Part 118/131 <gVpKb.23207$4N2.5358@fe08.usenetserver.com>
Part 119/131 <nVpKb.23209$4N2.15743@fe08.usenetserver.com>
Part 120/131 <vVpKb.23212$4N2.1374@fe08.usenetserver.com>
Part 121/131 <DVpKb.23215$4N2.14380@fe08.usenetserver.com>
Part 122/131 <KVpKb.23217$4N2.2557@fe08.usenetserver.com>
Part 123/131 <SVpKb.23220$4N2.18615@fe08.usenetserver.com>
Part 124/131 <_VpKb.23222$4N2.4998@fe08.usenetserver.com>
Part 125/131 <6WpKb.23225$4N2.22597@fe08.usenetserver.com>
Part 126/131 <dWpKb.23227$4N2.4173@fe08.usenetserver.com>
Part 127/131 <lWpKb.23230$4N2.371@fe08.usenetserver.com>
Part 128/131 <sWpKb.23232$4N2.19476@fe08.usenetserver.com>
Part 129/131 <AWpKb.23235$4N2.2809@fe08.usenetserver.com>
Part 130/131 <IWpKb.23238$4N2.18737@fe08.usenetserver.com>
Part 131/131 <KWpKb.23240$4N2.23206@fe08.usenetserver.com>
News-Service.com
News-Service offers fast usenet access starting at € 7,- a month.
click for daily random free open news server
alt.binaries.nl © 2002 Tommy van Leeuwen
disclaimer - contact info
51319561/131=391752
i think it is not total lines but total bytes, i checked also other posts it looks like that, i'll treat it this way then it will work.
jaapf
Post by jaapf »
:oops: I should have done the math myself :oops: I think you're completely right :lol:
Thomaaz
Post by Thomaaz »
starbbs wrote:I do not know if everybody know this, but newspro also supports the format at http://alt.binaries.nl
This is a free search machine. Just enter the thing you are looking for and klick on the found name. It opens a new page with lots of information including all the msg-id's
Just select everything on this page, copy it to clipboard and import it in newspro !!
It works great !. Now you can look for a file and if found import it in np.
It seems it's only importing the first 31 segments (www.alt.binaries.nl). In a post of more it wil show as incomplete. Am I doing something wrong or is it a bug. :oops: Here is the code
Code: Select all
Filename: (????) [81/92] - stoute.jongens.vol774+10.PAR2repost-badboys
Description: (????) [81/92] - stoute.jongens.vol774+10.PAR2repost-badboys
Poster: Yenc-PP-A&A
Newsgroup: alt.binaries.dvdr
Receive Date: 05 Jan 05:01
Total Lines: 16327930
Parts: 64
Message-ID's Part 1/64 <part1of64.eIOIHw3cnkj4XOuiNpFC@powerpost2000AA.local>
Part 2/64 <part2of64.eIOIHw3cnkj4XOuiNpFC@powerpost2000AA.local>
Part 3/64 <part3of64.eIOIHw3cnkj4XOuiNpFC@powerpost2000AA.local>
Part 4/64 <part4of64.eIOIHw3cnkj4XOuiNpFC@powerpost2000AA.local>
Part 5/64 <part5of64.eIOIHw3cnkj4XOuiNpFC@powerpost2000AA.local>
Part 6/64 <part6of64.eIOIHw3cnkj4XOuiNpFC@powerpost2000AA.local>
Part 7/64 <part7of64.eIOIHw3cnkj4XOuiNpFC@powerpost2000AA.local>
Part 8/64 <part8of64.eIOIHw3cnkj4XOuiNpFC@powerpost2000AA.local>
Part 9/64 <part9of64.eIOIHw3cnkj4XOuiNpFC@powerpost2000AA.local>
Part 10/64 <part10of64.eIOIHw3cnkj4XOuiNpFC@powerpost2000AA.local>
Part 11/64 <part11of64.eIOIHw3cnkj4XOuiNpFC@powerpost2000AA.local>
Part 12/64 <part12of64.eIOIHw3cnkj4XOuiNpFC@powerpost2000AA.local>
Part 13/64 <part13of64.eIOIHw3cnkj4XOuiNpFC@powerpost2000AA.local>
Part 14/64 <part14of64.eIOIHw3cnkj4XOuiNpFC@powerpost2000AA.local>
Part 15/64 <part15of64.eIOIHw3cnkj4XOuiNpFC@powerpost2000AA.local>
Part 16/64 <part16of64.eIOIHw3cnkj4XOuiNpFC@powerpost2000AA.local>
Part 17/64 <part17of64.eIOIHw3cnkj4XOuiNpFC@powerpost2000AA.local>
Part 18/64 <part18of64.eIOIHw3cnkj4XOuiNpFC@powerpost2000AA.local>
Part 19/64 <part19of64.eIOIHw3cnkj4XOuiNpFC@powerpost2000AA.local>
Part 20/64 <part20of64.eIOIHw3cnkj4XOuiNpFC@powerpost2000AA.local>
Part 21/64 <part21of64.eIOIHw3cnkj4XOuiNpFC@powerpost2000AA.local>
Part 22/64 <part22of64.eIOIHw3cnkj4XOuiNpFC@powerpost2000AA.local>
Part 23/64 <part23of64.eIOIHw3cnkj4XOuiNpFC@powerpost2000AA.local>
Part 24/64 <part24of64.eIOIHw3cnkj4XOuiNpFC@powerpost2000AA.local>
Part 25/64 <part25of64.eIOIHw3cnkj4XOuiNpFC@powerpost2000AA.local>
Part 26/64 <part26of64.eIOIHw3cnkj4XOuiNpFC@powerpost2000AA.local>
Part 27/64 <part27of64.eIOIHw3cnkj4XOuiNpFC@powerpost2000AA.local>
Part 28/64 <part28of64.eIOIHw3cnkj4XOuiNpFC@powerpost2000AA.local>
Part 29/64 <part29of64.eIOIHw3cnkj4XOuiNpFC@powerpost2000AA.local>
Part 30/64 <part30of64.eIOIHw3cnkj4XOuiNpFC@powerpost2000AA.local>
Part 31/64 <part31of64.eIOIHw3cnkj4XOuiNpFC@powerpost2000AA.local>
Part 32/64 <part32of64.eIOIHw3cnkj4XOuiNpFC@powerpost2000AA.local>
Part 33/64 <part33of64.eIOIHw3cnkj4XOuiNpFC@powerpost2000AA.local>
Part 34/64 <part34of64.eIOIHw3cnkj4XOuiNpFC@powerpost2000AA.local>
Part 35/64 <part35of64.eIOIHw3cnkj4XOuiNpFC@powerpost2000AA.local>
Part 36/64 <part36of64.eIOIHw3cnkj4XOuiNpFC@powerpost2000AA.local>
Part 37/64 <part37of64.eIOIHw3cnkj4XOuiNpFC@powerpost2000AA.local>
Part 38/64 <part38of64.eIOIHw3cnkj4XOuiNpFC@powerpost2000AA.local>
Part 39/64 <part39of64.eIOIHw3cnkj4XOuiNpFC@powerpost2000AA.local>
Part 40/64 <part40of64.eIOIHw3cnkj4XOuiNpFC@powerpost2000AA.local>
Part 41/64 <part41of64.eIOIHw3cnkj4XOuiNpFC@powerpost2000AA.local>
Part 42/64 <part42of64.eIOIHw3cnkj4XOuiNpFC@powerpost2000AA.local>
Part 43/64 <part43of64.eIOIHw3cnkj4XOuiNpFC@powerpost2000AA.local>
Part 44/64 <part44of64.eIOIHw3cnkj4XOuiNpFC@powerpost2000AA.local>
Part 45/64 <part45of64.eIOIHw3cnkj4XOuiNpFC@powerpost2000AA.local>
Part 46/64 <part46of64.eIOIHw3cnkj4XOuiNpFC@powerpost2000AA.local>
Part 47/64 <part47of64.eIOIHw3cnkj4XOuiNpFC@powerpost2000AA.local>
Part 48/64 <part48of64.eIOIHw3cnkj4XOuiNpFC@powerpost2000AA.local>
Part 49/64 <part49of64.eIOIHw3cnkj4XOuiNpFC@powerpost2000AA.local>
Part 50/64 <part50of64.eIOIHw3cnkj4XOuiNpFC@powerpost2000AA.local>
Part 51/64 <part51of64.eIOIHw3cnkj4XOuiNpFC@powerpost2000AA.local>
Part 52/64 <part52of64.eIOIHw3cnkj4XOuiNpFC@powerpost2000AA.local>
Part 53/64 <part53of64.eIOIHw3cnkj4XOuiNpFC@powerpost2000AA.local>
Part 54/64 <part54of64.eIOIHw3cnkj4XOuiNpFC@powerpost2000AA.local>
Part 55/64 <part55of64.eIOIHw3cnkj4XOuiNpFC@powerpost2000AA.local>
Part 56/64 <part56of64.eIOIHw3cnkj4XOuiNpFC@powerpost2000AA.local>
Part 57/64 <part57of64.eIOIHw3cnkj4XOuiNpFC@powerpost2000AA.local>
Part 58/64 <part58of64.eIOIHw3cnkj4XOuiNpFC@powerpost2000AA.local>
Part 59/64 <part59of64.eIOIHw3cnkj4XOuiNpFC@powerpost2000AA.local>
Part 60/64 <part60of64.eIOIHw3cnkj4XOuiNpFC@powerpost2000AA.local>
Part 61/64 <part61of64.eIOIHw3cnkj4XOuiNpFC@powerpost2000AA.local>
Part 62/64 <part62of64.eIOIHw3cnkj4XOuiNpFC@powerpost2000AA.local>
Part 63/64 <part63of64.eIOIHw3cnkj4XOuiNpFC@powerpost2000AA.local>
Part 64/64 <part64of64.eIOIHw3cnkj4XOuiNpFC@powerpost2000AA.local>
BTW. I love this feature. Is it also posible to make an export feature to be able to send it to someone?
uc2k2
Post by uc2k2 »
Once Import has been finished I also think that exporting might be a great feature, so you will be able to generate a nbz-file from a selected number of files.
yes, export would make sense too, i'll try to add it shortly (maybe to have it ready next week) since it will improve 'the flavor' of this feature by reducing its dependency on specific sites thus becoming generic.
for 3.72 i didn't set the auto update - http://www.usenetopia.com/version_r.htm still points out to 3.71 for this reason, but if the export is present the feature will be clearly useful also for people who don't use indexing services through subscription.
