Alex,
right now while newspro is downloading with attchments to be saved pending if you select more files > [Alt+K] (select folder) > create new dir > ok, newspro will now try to auto save the pending attatchments. durning this time newspro will pause for a short time depending on the amount of pending attchments, so if i want to select more files durning this time i have to wait until newspro frees it self up, is there anyway to disable the auto save after adding more file to queue?
autosave durning adding more to the queue
I don't see large delays here, in principle you can "block autosave but queue for it" in tasks menu->autosave and use download&save instead of save (save launches separate saving queues), then queue all you want and then to uncheck the option again, but while it saves it is no problem to save or download&save, if you use download&save it goes to the single autosave queue so it is less felt.
