Some text articles are not displaying bodies
I've noticed this problem before but now I've confirmed it and found a reproducible article to demonstrate it.
To explain: I've often read text-only groups where I've downloaded an article which was blank. Even clicking off the article and back on again does not fix it (certain times it has, especially with long text bodies where the body was truncated halfway down).
How I've realised there should have been a body is because the next message in the thread quotes the previous, original message. I only ever get to see these messages as quoted in a followup. This problem only seems to occur on the starting message in a thread - not on replies.
I've re-added all my groups and left all the text-only groups as article numbers. The group I've found a definite problem article is rec.autos.sport.f1 and the details are:
Code: Select all
Message-ID: <y7lte.70146$6g3.45759@tornado.texas.rr.com>
Subject: Paul Stoddart said it best...
Author: "John Smith" <someone@microsoft.com>
Date: Sun, Jun 19 22:06
The NZB is:
Code: Select all
<?xml version="1.0" encoding="utf-8" ?>
<!DOCTYPE nzb PUBLIC "-//newzBin//DTD NZB 0.9//EN" "http://www.newzbin.com/DTD/nzb/nzb-0.9.dtd">
<nzb xmlns="http://www.newzbin.com/DTD/2003/nzb">
	<file subject="Paul Stoddart said it best..." date="1119215198" poster=""John Smith" <someone@microsoft.com>">
		<groups>
			<group>rec.autos.sport.f1</group>
		</groups>
		<segments>
			<segment bytes="1479" number="1">y7lte.70146$6g3.45759@tornado.texas.rr.com</segment>
		</segments>
	</file>
<!-- Generated by Usenet Explorer http://www.usenetexplorer.com -->
</nzb>
What I've found is that if you download the article and go to Properties->Articles and check Show all fields but hidden, the body will show up. However this results in too much to wade through each time and will quickly get annoying, especially for short posts.
As the headers I prefer to see, I like to have shown:
Subject
From
Date
Lines
Newsgroups
X-Newsreader
At first I thought it was because I'd changed the config for this but it's not the case.
i've fixed it here, it will be in the next release towards the end of the week.
thanks.
Does the fix also apply to long(ish) text bodies that are truncated?
I've seen this mostly happen when I've downloaded an article while it was focused. Half the text is missing but if I click off and back on it, then it'll display properly. I have the view split so I can still navigate articles while reading the bodies. I think it would be fine if I had to double-click to open the articles to read them but I can't confirm as I don't use this method.
If you need examples, go to alt.binaries.warez.ibm-pc.0-day and filter Subject: nfo and Lines: <500.
EDIT: Actually, v1.0.3 fixed a scrollbar problem, maybe that's fixed it because I'm trying to find a specific article with this truncation effect. I'll keep my eye on it in the future in case I'm just unable to find any such problem articles at the moment.
the not showing body problem is not connected to redrawing.
yes, better give me a link to a specific article, if i see it here it is very fast to fix, scroll bar took about a week since i couldn't reproduce it, so i needed to guess what it could be even if i don't see it. in v1.03 i applied the same scrollbar fix to article views (so if it was connected to scrolling the issue may be fixed now), just there is some interface function in the microsoft framework with my code around its call and when i checked how it works i saw it ignores recursive calls so i did the same and it fixed the problem.
I'll try to find some specifics. Mostly it's on those stupid NFOs with half a mile of ASCII art before any of the useful stuff. However, it'll probably occur on any body where it's quite long - I just need to find something that currently exists in some group, somewhere.
long do you mean a long line or with many lines?
nfo is usually no text with attachment?
I should clarify:
The group I referred to earlier (alt.binaries.warez.ibm-pc.0-day) has posters that tend to post the NFO in plain text - not as an attachment. So you can imagine it as though you could view NFOs directly inline inside UE. (A feature request in itself since they are essentially just text themselves :) )
The lengths are normal widths (word wrap around 80chr) and a few hundred lines long. This is the only group I frequent that has posts of this nature and I don't check any other groups with text bodies as long as these.
try to check whether there is a difference between v1.02 http://www.netwu.com/ue/ue102reg.zip and v1.03 if there is it was scrollbar.
I need to go out for a while right now but I'll check when I get back. I should only be an hour or two.
Typical! I can't reproduce it with v1.0.2. :evil: The only thing I can think of that I'm not doing right now is that I've really only noticed this while I'm downloading other things. I fail to see how that could create a display problem, though.
I'll lookout for this and flag any articles which I find that show this issue.
if the other problem is still there (not the original problem which started the thread when you gave the nzb and i've fixed it here already) all we need is also one example
