ok what is left from the last to do list is filtering in search results views.
so i may finish with the client with the release and move to the server again, e.g. make it to handle higher retention (and when i finish with the server i'll contioue work with the older client to do list).
was: the next release (pre v1.14)
I tried the new "ages" display and noticed there's a problem with the display of ages < 10m. The decimal fraction is shown as a letter d instead of a number.
Additionally, maybe you could add an option to display ages in the format 0d00h00m? I think this would be a lot easier to read (for me anyway).
Regards, Hubert
yes i put d instead of %d and it shows leeter d instead of displaying the parameter. i've just fixed it in v1.13.
i first tried to show it in 00d00h etc. format but it looks like the format is more difficult to grasp, too many number-letter combinations to discern.
just people are mostly concerned with the server retention, e.g. the server has 30 day retention they don't want to download articles which will be close or over that, a single simple number is more appropriate for this purpose.
