Properties\ Server Tab
Tie
Post by Tie »
What do Msg-id Direct mean?
Properties\ server tab Msg-id Direct have a set check box and above it a (ON ) check box.
(BTW) my server is usenetserver.com if that help.
On the left had side of the screen( Enabled Priorty Strict) what are they for.
On the right had side of the screen New server ( Force Retention) how do you use this as will.
Sorry for all the stupid Q: But i read the help file ,webpage and form and still can not find all the info on a lot of thing with this program.
Thank for all your help. Tie
it is described on the home page:
Server priorities, server subsets and downloading bodies directly (revised) (new)
also look for info on forum (there was extended discussion on the former binnews forum but they decided to to go private after www.isonews.com went down).
msg-id direct is downloading bodies directly without downloading headers (download headers from some servers and bodies - from all servers).
