Vey Minor Annoyance with Scrolling
EdA
Post by EdA »
Using the mouse scroll wheel, in the Search Service window, it scrolls line by line. In all the other windows, it's a page scroll.
Cheers,
Eddie
MrEman
Post by MrEman »
Edit>Properties>Mouse wheel scrolls headers page at a time
Put a check in the box :)
EdA
Post by EdA »
Already checked.
Did you notice that I said it was ONLY the Search Service window that scrolls line by line. All the others scroll pages.
Cheers,
Eddie
the list view implementations are different, it could be well i forgot to handle scrolling, then need to move the related code from the task manager (it also uses the standard list view implementation), if i didn't add the special handler it uses your default windows settings, in short i'll check it.
the task manager scrolling was also default windows behaviour, i added my own handler for both, will be in the next version.
