posting process
telex
posting process
Post by telex »
When I post binary files - Where can I see the progress , which file is post at the moment and how long it takes til the end?
in task manager->post pane, click on advancing bars, it will show subject, so you can guess about the progress (it will post attachments in order). you can also make several tasks per server and post different posts through different servers in the same time (posting server can be adjusted in the post dialog before you click the post button).
