Is the search service down?
Paladin
Post by Paladin »
the server is accessible through remote desktop and running, i'm not sure all ports are open, cannot telnet to search service port for registered users and in the same time the port for trial version is open, i'm trying to contact dengle to fix that.
to fix it in the meantime in ... change ... to ... , it will work then. (*)
(*) "..." - i removed details from this post after the problem has been fixed since they are not relevant any longer, so not to confuse users.
ok it has been fixed, also i'll have an option to reset connection myself in the future, there was problem with router, so i'll remove the change port notice then from everywhere.
Paladin
Post by Paladin »
Thanks for the fast response.
