Req: "Are you sure"
Robert2413
Req: "Are you sure"
Post by Robert2413 »
It's very easy (by using the right click context menu) to accidentally invoke very time-consuming procedures like "reset headers" and "rescan headers." I think it would be good to have an "are you sure" dialog box to prevent slips of the mouse from accidentally invoking such procedures.
rescan headers you can cancel, you'll see it going away from the task manager header tasks as well.
reset headers is usually fast enough.
