Posts: 534 Joined: Thu Feb 27, 2003 7:29 pm
Post
by Josef K » Mon Dec 18, 2006 3:39 pm
You can change the port to a one that works but I notice Alex has removed the information for that so I won't reproduce it here. On a different port it works fine but I remember Alex said it messes with his statistics.
The search server is fine but the port is clogged. Unless Alex posts a different port number just wait till it's rebooted. I don't want to post it because it's his system and up to him what he makes public.
willko
Posts: 29 Joined: Thu Jan 22, 2004 4:10 pm
Post
by willko » Mon Dec 18, 2006 4:24 pm
All ports down as of 4:30 PM GMT.
Post
by Josef K » Mon Dec 18, 2006 5:29 pm
willko wrote: All ports down as of 4:30 PM GMT.
Still working for me on another port. Looks like the server needs restarting or a full reboot.
Posts: 4553 Joined: Thu Feb 27, 2003 5:57 pm
Post
by alex » Mon Dec 18, 2006 6:39 pm
where is the first message? i see only the reply.
the router went down again, the second port 2021 is still working, if you change the port in settings it will work.
probably the router should be replaced.
i'm trying to get the router reset in the meantime.
Post
by Josef K » Mon Dec 18, 2006 6:56 pm
alex wrote: where is the first message? i see only the reply.
The OP must have deleted it - it was there originally
Post
by alex » Mon Dec 18, 2006 7:08 pm
ok i've rebooted the router, all works again.
Post
by Josef K » Mon Dec 18, 2006 7:25 pm
Does it still matter if we use one port or the other for your statistics and such? Should we change back to 2020 every time?
Post
by alex » Mon Dec 18, 2006 7:59 pm
better to use 2020, the problem with the router will be sorted out, especially if it happens again.
willko
Post
by willko » Mon Dec 18, 2006 8:26 pm
thanks alex - top service as usual.
btw - happy xmas!
