Please add alt.binaries.echange-web to the search engine
laitier87
Post by laitier87 »
It's a new group feeded by some very active french guys.
TIA
added, need to handle some bureaucracy here, so with some delay.
laitier87
Post by laitier87 »
Thanks for everything.
