i've added it (headers are already there), initially it will be at 117 day retention then growing (it is about 2% of files, the rest is at 150 days), since it is the current max newsservers header feed retention Ngroups/UNS, I see the newsgroup is about 2.7M headers.
later i'll try to write something to find differences between newsgroup lists of news and indexing servers.
i've synchronized the current newsgroup list for non-picture groups no "pict" in the name, it is now in the process of downloading headers.
with picture groups i'll do it a bit later, i have an idea how to draw picture groups from the backup server as it is done now already, but in the same time to optimize its usage so we won't sacrifice retention and update the whole newsgroup list on the backup server as well, maybe i'll do it later today or tomorrow, most likely to do it we need a small server code change, i haven't checked it exactly yet.
