Search Function 1.97 <-> ISA 2006
jaap114
Post by jaap114 »
Ever since I've updated to version 1.97 I can't use the search function any more.
In the previous version I made a seperate rule in ISA server to connect to port 2020. As I understand the current version doesn't offer a static port any more, so how can I connect/use the search function without a socks v5 proxy? :evil:
I'm already stuck at point where the software tries to update the search functonality.
With ISA Server logs and Wireshark I managed to figure out that it tries to get an update file (UeSrv) from netwu.com. I'm receiving the file, sending an ACK back to the update server. After that total silence, after some time UE times out claiming my firewall is blocking trafic?
Howto fix this? :?:
yes it goes to the ue website to download uesrv.txt which contains host and port, so let it do it when it requests it (it works through http so it is port 80 www.netwu.com, the ue website is www.netwu.com/ue), it also stores those coordinates in its registry, so unless i changed something in the configuration here it won't go and download it again. i could also to add an option to update configuraton from a file i'm not sure though it makes sense.
right now the search server is the same as in the previous version (the port you mentioned).
if i change the configuration the port may change, but changes in configuration will be rare and commonly associated with increasing retention, the new scheme is able to provide unlimited retention without software upgrade but in practical terms probably there will be only one or two changes in the future depending on how things are going on.
ue uses the website only in two ways now: first, check for updates - reading http://www.netwu.com/version_reg.htm if check for updates is enabled in properties->general->check for updates and since v1.9.7 reading the search service configuration, it is the only purpose, so should be no problem to allow this.
if you want exact details about access point especially if configuration will change just contact me, but the access will basically remain static.
Why not just state the current port assignment in Help->Diagnostics? A few people now have been mentioning that they are having some sort of firewall trouble due to this.
it is possible to add manual loading of the configuration file.
also add show search service configuration option in the help menu and direct users there if search service requests generate socket error messages.
hardwiring configuration so changing configuration would requre a release is not a good idea, since the new scheme is more intricated and i want to change things of fly if i need without making a release.
we'll revisit the matter when i'll be back in 1 day (was not here for about 5 days).
jaap114
Post by jaap114 »
My problem is that it apperently receives configuration file but doesn't do anything with it.
Everytime I try searching something first I get a message box saying:
Search service configuration has changed or has been deleted.
After some time (in wich I can see with Wireshark that it receives the configuration file) I get this error:
Error updating search service configuration, Pleas ensure that UE is not blocked by firewall from downloading the configuration from the UE website.
I've tried to reset the configuration (Edit -> Properties -> General TAB -> Reset Configuration) with the same result.
Alex: You said it saves the information from configuration file in the registry. I can't find anything in the registry (HKLM doesn't contain any UE keys and HKCU only contains only a few entries, but nothing about search). Where in the registry does the program safe this information?
Is this problem firewall related or is something else wrong?
jaap114 wrote:Where in the registry does the program safe this information?
UE doesn't use the registry for its settings. The information will probably be stored in reg.dat which, of course, is a binary file and that always makes it harder to read.
the configuration file is at http://www.netwu.com/ue/uesrv.txt
if you have trouble getting it from UE website, and you have your own website you can try to edit the windows hosts file and put uesrv.txt on your own server so UE will go there and download it.
another way maybe is to put UE database on a flash drive and access network from less restricted environment and to make at least one search, then reg.dat will contain the current configuration.
i'll try to add the manual load configuration from file option in settings, just right now I'll first will be doubling retention to see how it works with the new computer.
what i don't understand you were able to set UE to go to uexxxxxxx.dyndns.org port xxxx but you cannot allow it in the same way to access www.netwu.com port 80?
