Feature request: finished tasks in unpack
Ustinov
Post by Ustinov »
I really love the new unpack feature. Glad it came just before I had to renew my license.
I also like I now have a way of quickly going from a download task to the folder it is being saved in (space on the task in the unpack task list), as I use several download folders.
Would it be possible to leave an entry for finished tasks. So it deletes all the par and rar files afer unpack, but I keep a quick link to the download folder? So I can check my mp3 tags, par example.
ofcourse with a button to clear all finished tasks :)
right now you can toggle clear/delete on success in properties->save/unpack
when the option is unchecked all files will be preserved, when you check it all files which were finished earlier will be cleared.
