Eve since the search went down and came back up recently I'm having a problem.
The search goes okay but anything I try and download fails.
I get a litle red circle with a white x.
EVERY SINGLE TIME.
Also, I use another newsreader for a small numer of groups and with that I'm having no problems. It's just Usenet explorer that can't download anything.
Suggestions??
searches go okay, but i cant download
the red circle appears (you are talking about the search results view apparently) e.g. when you mark something for download&save and then press "cancel".
also it could happen when e.g. server db was corrupted somehow but it has never happened in the past, if i have a proof there is even one corruption i would run integrity check and replace damaged files from parallel running copy.
what exact download/save option do you invoke?
can you give me an example of a search string and then which exact results you are trying to import (any example which gives you the error circle)?
for example if you search for
subject: death*race*2008
author: fake
then do you see the error circle (i don't)?
author: fake
