Providers increasing retention to 365 - 400 days
dracula
Post by dracula »
Is the UE search also going to 365 days as the newsservers? :lol:
yes, should be no problem, i'm working on software adjustment to make it not expensive as to additional hardware, most likely will finish tomorrow.
i've restarted the server with the updated software, so increasing retention now will be only question of adding hardware.
dracula
Post by dracula »
Great Alex, your the best. :wink:
dracula
450 Days!
Post by dracula »
Thanks Alex for the big retention upgrade again. :lol:
