Search Question
intravenus
Search Question
Post by intravenus »
Is there a way to search so that the results only start with a certain character ? For example i searched for: ER.S01 but i get too many results with letters and numbers before the "E" like Fixer.S01, The.Handler.S01, Starhunter.S01 etc (using Boolean wildmatch search). Using : "ER.S01 (adding ") seems to eliminate most but not all unwanted results.
cheers
Re: Search Question
what unwanted results left if you use the quote?
i guess you use boolean wildmat search.
intravenus
Re: Search Question
Still finds Everest.ER.S01 and Bizarre.Animal.ER.S01 but that's ok. It's narrowed it down enough for me. :D
cheers
ps, i was using Boolean wildmat search in my 1st post. (Edit: spelling)
