25 Apr 25: The search service monitor sound alarm was not always activated to alert me in the case of an unplanned server restart (e.g. tripped breaker) like it happened today. This is now fixed and thus the search service downtime of this nature is less likely.
If someone has problems with firewall please pm me for updated outgoing port layout - there is small change to accomodate rising retention.
There will be one more adjustment when the oldest computer (since 2005) will be completely taken out of service, it is still running, but starting today it won't normally serve user requests.
