Selectable Message Bar
boston62
Post by boston62 »
Like to be able to hide tabs in the message viewing, if I didn't want to see SIZE or AUTHOR. I could just unselect them. Thanks.
Re: Selectable Message Bar
You can just shrink them to the zero size by dragging the divider.
Then invoke window menu->propagate current column order/width...
boston62
Post by boston62 »
alex wrote:You can just shrink them to the zero size by dragging the divider.
Done and thank you..
Just Registered your program...
