search failed (9)
25 Apr 25: The search service monitor sound alarm was not always activated to alert me in the case of an unplanned server restart (e.g. tripped breaker) like it happened today. This is now fixed and thus the search service downtime of this nature is less likely.
topcat236
search failed (9)
Post by topcat236 »
getting this error to many users try later
ehmbe
Re: search failed (9)
Post by ehmbe »
Same error here.
:cry:
Wintergon
Post by Wintergon »
I am getting it as well
JackieChun
Post by JackieChun »
I am getting this error too from about 2 hours now.
dwhite32
Post by dwhite32 »
same here, started last night and still happening this morning
dvd.collector
Post by dvd.collector »
same here too
there was and maybe is bad header feed from ngroups server.
i've copied header data from backup and restarted it without that feed, should work now.
