Dual servers with separate log ins.
Mist
Post by Mist »
Installed news.grc.com this morning and collected newsgroups. All went well except for the red !. Checking the problem, I found all newsgroups (old and new) had double servers in my case news.grc.com and bignews.com. Is that correct?
If not, how do I remove a server from those newsgroups that don't belong to it?
Each server has its own login. Anything special I need to do here?
Thanks.
Mist
Re: Dual servers with separate log ins.
Check tasks menu->tasks manager, click the red question sign tab to see the error message.
No problem to have several servers, you can enter userid/password when adding the server or change it in edit menu->properties->servers or through context menu advanced->rename server option in the workspace.
You can also define to gather headers only from one server in edit menu->properties->servers "get headers" check box.
