Is there a watch folder for auto import, download and unpac?
tijgert
Post by tijgert »
I would like to send nzb files via remote to my little download computer with UE running and put them, from wherever I am, into a folder that UE watches. I'd then like UE to automatically import the nzb's and automatically download, save and unpack the files. All while I am far away from home.
I can very simply do the import, download and save when I am behind the computer, the trick is that I want UE to do it automatically when it detects nzb's in a certain folder. I can't figure out that last part.
Can UE do it? How then? And from what version does that work? (if it can, because I am still using v2.7+).
jonib
Re: Is there a watch folder for auto import, download and un
Post by jonib »
tijgert wrote:Can UE do it?
Sure
How then?
Just put the .nzb files in the Import directory where UEs database is.
Don't know from which version but UE has supported it a long time.
For more info read this Handling NZB files
jonib
tijgert
Post by tijgert »
Understood and working!
It was there all along, I just had to be pointed towards it.
Appreciated!
