Kill filter for single author posts
t-water
Post by t-water »
Spam messages have increase to a dramatic new level in the last couple of weeks. Is it possible to design a Kill Filter to remove the header from a single author? In other words if the author posts two messages to a forum, don't kill the header. This won't get all of the spam but it would get rid the majority of it.
Tom
Re: Kill filter for single author posts
try to give me an example, you can pm as well, maybe i will have an idea. usually it can be handled with existing options.
dxcarnadi
Post by dxcarnadi »
I am interested in the solution.
For example in the newsgroup alt.binaries.e-book.technical etc. there are many
o small RAR-files or ZIP-files
o they contain an EXE-file.
I never activate this EXE-file .. I delete it.
How should I create the "kill filter" with "existing options"?
Thank you.
