Par download - Some downloads don't continue
Terry
Post by Terry »
Several corrupt downloads can't be repaired because UE doesn't download the par files.
I have hundreds of par files waiting at the top of my queue with highest priority but they simply don't get downloaded.
Pausing everything else in the queue doesn't help.
Is there a way I can force the par files to be downloaded? (so I can repair them manually)
Code: Select all
Client:       Usenet Explorer v4.9.3 - 64 bit (registered)
OS:           Window 7 Ultimate  - 64 bit
Anti Virus:   Avast Premium - 64 bit (updated daily)
Firewall:     Avast Premium - 64 bit (updated daily)
Usenet:       Eweka
Re: Par download - Some downloads don't continue
do you have unpack enabled?
if not do you have mark limited volume of par2 files for download in par2 menu checked?
Terry
Post by Terry »
Everything in the unpack section is enabled.
"mark limited volume of par2 files for download"can't be selected.
The menu entry is black, but the submenu is grayed out.
Code: Select all
Usenet:       Eweka
Do you see any remaining data files in the "articles" tab or in the "?" tab (second next to the "articles" tab) in tasks menu->task manager?
Also click the "unpack" tab in the task manager and expand the par2 set, you should see there data files pending somewhere in the queue.
Check also the unpack queue or the unpack task is not paused.
