Newspro disappear! Help!!
wah
Post by wah »
I am using WinXp and just made an on line update in MS update sute.
After rebooting, I run newspro but it does not shown up in any active window. I know it is running (it is even downloading the articles I marked for download before the program disappear), I just can't bring it up in the active window anymore.
What has been wrong? ANy help will be appreciated.
bruce73
Post by bruce73 »
What update did you install? Are you sure the program isn't simply minimized with an icon in the Taskbar?
wah
Post by wah »
bruce73 wrote:What update did you install? Are you sure the program isn't simply minimized with an icon in the Taskbar?
I updated everything whatever provide on the MS site and then Newspro disappear.
Now I roll back the system anmd reinstall the win update again by selecting only security patches . It is ok now. I guess it is a problem with either the nivida or network update drivers/
