Version change in 3.73 ?
poma5
Post by poma5 »
Alex,
I just downloaded and upgraded NewsPro to version 3.73 from 3.72, but when I started NewsPro up and looked under *Help* *About NewsPro* it now says that I am running version 3.71. What happened?
J.P.
check the shortcut, probably it points out to an older file.
poma5
Post by poma5 »
Alex,
The shortcut points to the same place that NewsPro has been installed in for the last 2.5 years. I always install over the previous installation. Did you check your links on your page?
J.P.
poma5
Post by poma5 »
:oops:
Sorry Alex,
Never mind. I just forgot to run the extractor. I unpacked the zip file into the directory where NewsPro is located but did not run the NewsProExtractor.exe.
Thaks for your prompt responce.
J.P.
