Launching JPG (instead viewing online)
zorro
Post by zorro »
Hello,
I'm a new user. I'm wondering if there is a way to configure
NewsPro to launch all attachements (including JPGs) using the
external program associated with this file type.
Thanks,
-zorro[/b]
you just doubleclick the file icon or the image, then the default application will be launched (you can also use 'open with' from the context menu).
