Truncated reply pane
Jessicadog
Post by Jessicadog »
When replying to a Usenet text message that is very long (a thread with many replies) the message is truncated in the reply pane. Is there a setting that I am missing?
Jessicadog
Re: Truncated reply pane
Have I failed to make the question clear? Entirely possible. Or is there no way to fix this?
I checked the source code, it limits the reply text to 10000 characters, but in principle I can increase or remove the limit altogether.
Jessicadog
Thank you Alex.
I used to use NewsPro until you produced this much better application, thank you.
I use UE for two things. Binary of course and also messaging which in the often produces very long threads.
A solution to this would be very helpful.
5000 would certainly be long enough, perhaps even 3000.
May I make that request please? I will do so in the development area.
Thank you
I've added the option in the next release, it will be in edit menu->properties->post, if the release is further delayed I'll pm you a link.
Jessicadog
Alex
Thank you.
Probably not important for many users but very important for me!
Regards
I've sent you the link through pm.
I've compiled a 32 bit version only.
