Splitting NZB into Rar Sets
maltmaster
Post by maltmaster »
Is there a procedure for determining which <file> tags in an NZB file go together to form a complete RAR set? UE can handle this for NZBs that contain multiple RAR sets. There doesn't seem to be a standard notation for "part i of n".
Regards,
maltmaster
Re: Splitting NZB into Rar Sets
Actually as far as I know the problem is the opposite - sometimes file names are random from one part to another, and if not to ignore that it ends with multiple files instead of one. I tried to limit it to certain patterns.
I didn't hear about mixing several download into one, but if done correctly probably UE should handle it as it can handle several files into one post.
If there is some new way to post which is common, I could check it out.
