Attachments won't save
jds
Post by jds »
I downloaded several articles in a series and used the "Download & Save" option from the right-click menu. It shows the articles and attachments downloaded successfully and that all parts of the article are there, but it didn't save the attachments automatically and it's not saving anything manually. What am I doing wrong?
Thanks for a great program,
Try to open the articles and check their source, if these are binhex attachments - save source and decode it with winzip.
Also these maybe corrupted posts, if these are partial messages - disabled partial autosupport (partial menu) and check whether something is wrong with the post.
If it would save manually but didn't save with download&save as fast as you wanted - you could reduce the delay in properties->general, autosave per but apparently it is not the case here.
jds
Post by jds »
Thanks Alex. It seems there is a problem with the post. Though the size of some of the attachments initially shows a 24000 or so lines, when the download is complete they are only about 35. Thanks for your time. :oops:
