News Group Download
Grandpakewl
News Group Download
Post by Grandpakewl »
Rebuilding my PC after it died. I wanted to set up a download from a specific newsgroup and forgot how. Looked thru the manual but it does not match the current version. Any instructions available?
Re: News Group Download
In View menu->Workspace right click on the newsgroup and invoke Open&Get new headers or similar options.
If nothing appears you can try to uncheck Edit menu->Properties->Enable built in spam filter especially "Downloadable", but you should see nothing useful there.
Grandpakewl
That's the path I remembered but when I do that, it opens up a window that is labeled "Import&download&save" that looks as if it is asking me for the name of an existing *.nzb
In edit menu->properties->newsgroups check if the newsgroup entry icon to the very left isn't marked with "I" (Import type), if so delete the group and create it again with "Import group" unchecked.
Grandpakewl
Kewl beans...back in business. Much appreciate all the help.
