I had downloaded all the bodies from an imported nzb file. But I needed to redownload them again. The only way I could do it was to reset my database. IS there an easier way?
you need just delete bodies (select the articles and invoke 'delete bodies' from the context menu).
if you want to reimport, should be no problem, for the import group previously deleted/purged headers are ignored, for other groups you can see deleted in edit menu->show deleted.
