Saving files to a directory (minor problem)
griffpa
Post by griffpa »
I've noticed NewsPro creates the directory from the last time a save command was issued if that directory has been deleted. I'm sure it's by design, but since I usually download files to a particular sub-directory and then delete the sub-directory when finished, it's an extra step to manually delete the empty directory NewsPro creates the next time I save files.
i changed it here:
<snip - download the latest version>
still if you defined a default directory per newsgroup in properties->newsgroups it will be recreated, only if it is the common default directory (the topmost entry in properties->newsgroups and the newsgroup uses the default it won't recreate it and will move left in the path instead).
griffpa
Post by griffpa »
Thanks for the quick update, it works great!
