Reading articles
plasmannc
Reading articles
Post by plasmannc »
Probably something simple but.....
If I have bodies on several messages how can I read them one after another. At present I double click the header which opens the article. Then I have to close and double click the next, etc.
Once one article is open is ther a key that automatically advances to the next with a body and opens it.
you can split the newsgroup window (see the "windows menu" also there is a toolbar icon looks like splitted window to do the same).
if you don't want a split window instead of doubleclicking you can use 'enter' to open and 'esc' to close article views.
also there are several relevant shortcuts in the newspro help file.
