The search service protocol has been changed
owpex
Post by owpex »
I receive this message when I try search something:
The search service protocol has been changed,please upgrade to the latest version
My version is 2.2.1 could somebody help? thank you
jonib
Re: search failed
Post by jonib »
The current version is 2.9.2 download here. your version seems old; you might also need to reenter your latest serial when extracting it.
I have made a tool to check and automatically update UE here. Only 32bit version for now.
jonib
owpex
Re: search failed
Post by owpex »
Everything is ok now,thank you jonib
MrEman
Re: search failed
Post by MrEman »
Worked fine for me in ver 2.9.2
Now I have the same message in ver 2.9.3......Protocol changed???
I did a reset from the Search/Import settings tab.....
Still not working.....
MrEman
Re: search failed
Post by MrEman »
OK!
I see there is now version 2.9.5
Upgrade cleared up my problem
All is well now! :D
Re: search failed
v2.9.5 introduces simple search syntax which is sufficient for many users with no need to type control characters, so the protocol change notice.
Boolean wildmats are now implemented more effectively on the server side as well.
In the next version maybe I'll add forced check for updates when protocol has changed, before v2.9.1 it didn't change for couple of years.
