Problems with Newspro trial
Polgara
Post by Polgara »
I have a problem with the trial version of Newspro. I tried to instaal and configure it today. I can download it and open it.
When i close Newspro down after configuriing it I can't start the program again. I've tried everything, but i can't figure it out.
I hope someone can help me cause i really intend to buy this program, but only if it works
if you minimize the program its icon will be in the system tray (uncheck edit menu->icon in the system tray to see it as a button in the windows task bar).
if you started the executable from zip - just save newspro.exe somewhere, once you created the database it will open it disregarding the executable location.
Polgara
Post by Polgara »
When i start the program i see the icon appear int the system tray. But as soon as I put the mouse pointer on the icon it disappears. I just can't open it.
I've tried to start a new with the program, i deleted everything (i think). I even deleted it in the register but that didn't solve anything.
When i start the program i get the message "This is trial version. Check shortcut/download version for registered users." It can't be that my trial periode is over cause i downloaded it and installed it yesterday, not 30 days ago.
before you deleted database/registry entries did the icon just disappear or it always gave the "this is trial" message?
if you always saw the message box it means the program thinks the trial has expired (it is not a problem), if there was no message but the icon disappear - the program is terminated by something else, although if you started it once should be no problem to start it again then.
Polgara
Post by Polgara »
I didn't get that message the first time i got that after i tried to start the program several times. At first the icon just disappeared over nd over again.
But i got it working. I reinstalled de trial version and it works. I don't understand why it happend but it works.
