Problem wit saving data (yenc problem?)
ElimGarak
Post by ElimGarak »
I have often Problems with saving files using registered version of newspro 3.8
Two actual problems that encountered right now:
i donwloaded from alt.binaries.sounds.mp3.new-age
(electronic) Richard Burmer - Collections From The Gallery (OOP Japanese CD) (mr @ 224/48) [01/12] - 01-Across The View.mp3 (00/36)
(All the files od this record).
After saving the filenames (spaces in the names) are mixed up
in my directory it shows up like:
01 -AcrossTheView.mp3
02-Magellan.mp3
03 -TurningToYou.mp3
04- WinterOnTheWind.mp3
05-Reunion.mp3
0 7-BhaktiPoint.mp3
06 -CurioDance#2.mp3
08- SettleNearTheSunset.mp3
09 -TheTurnAgain.mp3
1 0-Ela-A.mp3
1 1-WillowSong.mp3
12 -CloserThanLove.mp3
(please review sourcecode of displaed page as spaces are not displayed accurately in the forum)
Sometimes the files are not saved completely
also from the same newsgroup
Carol Nethen - 1989 A View From The Bridge nmr@VBR [11/14] - yEnc "09 A View From The Bridge.mp3" (*/16)
Every second file ends prematurely at 376 kb (like 03toccata,07WesternStar..)
i dont know why this happens, other (webbased) decoders dont seem do have any problems with decoding filenames and files correctly. Is there any Option i have to set? Anything i did wrong?
Im really clueless about this problem (it doesnt seem to be a system problem because its the only program on my system that produces this kind of errors)
Hope my description was exact enough, pls
help me with that problem,
greetings
ElimGarak
it is your firewall corrupting data (zone alarm?).
i downloaded and saved
Carol Nethen - 1989 A View From The Bridge nmr@VBR [11/14] - yEnc "09 A View From The Bridge.mp3" (01/16) ... (16/16) - Reassembly
the size 5,881,161 bytes the same as in the yenc header:
ybegin part=1 line=128 size=5881161 name=09 A View From The Bridge.mp3
then,
(electronic) Richard Burmer - Collections From The Gallery (OOP Japanese CD) (mr @ 224/48) [07/12] - 07-Bhakti Point.mp3 (01/55)
the first part:
begin 644 07-Bhakti Point.mp3
etc.
so the name newspro will use when saving will be
07-Bhakti Point.mp3
and not
0 7-BhaktiPoint.mp3
ElimGarak
Post by ElimGarak »
Yes im using zonealarm 5.1.033...
Are there known issues about zonealarm corrupting data?
