rescan hangs
brianw
rescan hangs
Post by brianw »
I have a group that will hang everytime I do a rescan on it now.
The rescan makes it thru the first pass and then hangs on the seconds.
This connection starts using 100% cpu but has zero bandwith showing.
Looks like some timing bug on the second pass or some endless loop.
I have No firewall installed and No 3rd party tcpip anything on this
box. :cry:
brianw
Post by brianw »
I found your link to the fix for this. I just downloaded it and test it.
It works. Fixed the problem.
Thanks!!!!!!
i need to make a release to include the change (it works, i mean to put it on the webpage).
the problem is i want to make additional changes to possibly handle power post abusing references when posting pars plus few small things and there is a complex synchronization procedure (the order of tasks for me to implement) between the current maintenance and the work for the future, i hope to arrive to the point in one week :)
bassie
Post by bassie »
brianw wrote:I found your link to the fix for this. I just downloaded it and test it.
Thanks!!!!!!
I am also using it, and I also think it works better.
:D
