Filter to extract and delete message with no attachments.
pdxsam
Post by pdxsam »
Alex,
I'm trying to create a filter that would select all headers without attachments and get rid of them. In th filter editor the message
choices all predicate on "are". There's no way that I can see to
specify that messages have no attachments to them.
It would be valuable to have that since I usually go by hand in
binary groups and delete all the headers without attachments for
a better view of what's there.
Possible to add this?
Sam
You cannot tell whether a message has attachment or not but it is possible to make a good approximation.
For example to include:
1. all partial messages (the last part can be of any size, so at least for kill filters it is needed)
2. all non-partial messages with the number of lines less than a certain number
3. include all subjects containing .nfo,.sfv,.zip etc.
the filter would be like that:
messages are partial, apply to all, select
lines > 100, apply to unselected, select
subject contains ".nfo|.sfv|.zip|.m3u|\(1/1\)", apply to unselected, boolean wildmat, extract
if I missed something you can add more conditions.
you can also apply the filter as initial filter or through edit menu->message filter - without deleting non-matching headers.
