Procedure to upgrade the trial version to registered version
ramanng
Post by ramanng »
I have tried NewsPro for several days and I found it's the program I needed. I'll registered it. Before I do so, I would like to know the procedure to upgrade the trial version to registered version without clear the database and the settings.
Thanks in advance. :)
It is enough just to replace the executable (newspro.exe - register it in help menu->about), all the rest is preserved.
dhm00
Post by dhm00 »
Or download the registerd user version en enter the serial...
Tha*Lunat!k
Post by Tha*Lunat!k »
Same thing :)
